Jleadbeater
I like that idea, seems much cooler and ventilated down there.I’ve just fitted a 200W solar panel to my 2023 Birchover. The ‘electrical cupboard’ in mine (pictured below) was only 35mm deep so there was no space in which to install a Victron SmartSolar 100/30 solar controller. With your installation, it looks like they’ve found a solar controller that will fit in that space (or they’ve increased the space to accommodate it). It worries me that there is limited airspace with no ventilation - a recipe for overheating it seems. In the case of other Hillside factory installations, it seems the solar controllers have been fitted in the wardrobe itself which seems plain daft to me.
In my case, I decided to fit the controller in the wheel arch void underneath the rear cubby (second picture) where there is much more space, some airflow and cooling. I found it was easy to feed the +ve output cable from the controller back to the electrical cupboard to connect to the +ve input on the 12V fuse block (not isolated when the engine is running) and the -ve cable back to the body earth stud that is just in front of the offside rear lamp unit.
In spite of the nasty rat’s nest of factory wiring, the absence of manufacturer documentation and the lack of cover to the rear of the 230V sockets, I found it a fairly straightforward to fit solar. I fitted a 20A fuse between the controller and the fuse panel input (shown before connection in the last picture) and a 2-pole isolator in the solar feed (between the consumer unit and heater switch in last picture).
Isolator - presume this is from the solar panel to the MPPT, and is this necessary or your preference?
The +V connector out of the MPPT, this goes to the fuse block, on mine it goes to the 12v socket, Presume its ok to leave that as is provided I put a 20 amp inline fuse is before the socket?
