Help with compatibility please mfsw
If you’ve got cruise in the stalks (and intend on keeping it there) then this is not the right wheel. I believe you can swap your stalks for versions without CC, then add the wheel, and reprogramme with VCDS since your must be a EUR6. Not possible with my EUR5. I should say I can’t be 100% certain this is the case and there might be other members who have done it that way.
After having read several threads on the subject I was under the impression this would work. Most of the information is in this thread and I've also bookmarked this post from another thread since I think this is what is ultimately required, ie repinning at the BCM.
You shouldn't need to run any additional cables since you already have cruise.
You don't have to swap stalks but I think whichever cruise is used on first (ie stalks or wheel) that's all the van will use until it's restarted.
I saw you asked about coding too, I believe if you are a VIP member a local VCDS user will do it for you.
I can't justify VCDS cost so I'm going to get an ODBEleven to code mine.
