Help - wiring up sub woofer to amp
Gavinsky23
Hi all
looking for a bit of help. My kombi had a hertz amp, sub and rear speakers fitted when I viewed it. After purchasing and converting, the converter removed the sub as it was under the now swivelling passsenger seat. I’ve now found a place for it and thought I could just connect it up to the amp.
I’ve connected it to the rear channel but now just noted I don’t have the ‘sub input’ connection as noted in the instructions for the amp below. There is no sign of this cable anywhere.
given it was working before I’m guessing it was either configured differently or the cable has been disconneted and is now somewhere else when I got it converted.
Is there a simple way to get the sub to work without this?
See pic of amp and picture from manual that I was trying to replicate.
Any pointers would be appreciated.17C536C3-0DD8-4DDB-BA0C-F3FA8545AAAF.pngAE83A92B-8576-4215-8DF1-B539DCBF0639.jpeg
Sorted now... just realised there is a ‘rear in’ button. I thought this activated the rear but now realise it’s if there is a rear in signal.
