I already went through those downloads and this led me to recheck fuses SC12, SC14 & SC61.
All are fine.
The front a/c is working fine. It is just the rear blower that is dead. Or at least the controller for it which is completely dead.
I am booked to have the problem checked by a Dealer and it looks like I'll have to wait. Carista is giving me a fault code relating to the "Heater & air conditioning 460035" (Along with two other random faults which wont go away, but I've not worried about these as there are no faults on the dash.)
My concern is that when my under seat mods were done, all of the under seat bracketry was removed to make room for the required kit. I am concerned that the Dealer will tell me that i have caused the fault despite the fact that everything has been working fine for 6 months since the mods were undertaken last October.
There is a reference in one of the downloads which worries me. TSKVL - Coupling point in left seat. I disturbed everything under the left seat when the van was new, but only insofar that i unplugged everything and plugged it back together (in the same housings) without the bracketry to make room for my kit.
Here is a picture of what was left with after losing all of the housings under the flooring prior to installing my kit under the left seat base.
The one and only relay that is in the above photo is marked with the marking "645". I think that this relay deals with the rear window heater, but I'm likely to be wrong on this?
At the time of the seat base works, I did leave the relay accessible as can be seen in the below picture taken at the time of the works and i have checked all fuses under the left seat. Weirdly the fuse that is referred to as the TSKVL 20A Coupling point (No 4) is missing in my install and always has been.
I have checked all of the fuses under the left seat and all are fine.
I also have no idea why the Downloaded "Relay locations for a 6.1" show 7 relays under the left seat. I am positive that there was only the one described above, but I have a rear heated screen and assume that all models have the relay J7 for the battery isolation, so unsure why I only have the one relay.
Does anyone have any other info on fuses and relays on late T6.1's as mine seems to be different to that referred to in the download section.
I am confuddled and reached the end of my ability, without someone pointing me in the right direction.
Basically i now don't know how much to panic as I am worried that the VW dealer will blame me and then walk away. (I worry that they will take advantage of the fact that warranty is voided by my removal of the under seat bracketry.)
It may be that it is likely that the control panel is simply u/s and I am worrying unnecessarily as the dealer will just replace this, but I thought I'd seek advice on this forum before having my pants pulled down at the dealers!
