Aren’t they the old style ISO connectors?Help needed to identify the 2 brown connectors. And hopefully where I can order the opposite parts (the bits that would plug into these brown connectors) and the relevant pins.
those are the standard ISO speaker blocks. . . . . . 4 Chanel
green, white, grey, purple . . . . .
that is a break-out lead that will allow you to the the speaker-level signals out the radio to feed and AMP, then connect the AMP side to the speaker-side block.
https://amzn.to/2SuwdCs
https://amzn.to/2SrhVTf
https://amzn.to/37f5q1b
Edit - beaten to it in major style by WikiDell![]()
What, running your own looms from the amp to the doors?
And using a 4chnl amp to split the tweeters out?
Doesnt the speaker set come with a crossover?
What amp you looking to use?
yes if thats what kit you want to use, then that setup will work...Thanks guys.
SO I reckon I get one of these:
Then this lead to the amp:
Then make my own loom from the amp to speakers using this I got:
Any suggestions of wire I should use?
TIA
