Perfect many thanks
Technically is not my kit it's the genuine VW led headlights same as you get from the factory, I just assemble all the bits and make up the required wiring to install them but no they are not dotted but give a more linear line of lightI'm also not a fan of the dotted LED's. Besides, this upgrade is to fix the 'tealight' issue, not issues with DRL's. I'm not sure how long I'll be able to resist upgrading as the standard H4's are by far the worst headlights I've ever had on a vehicle. I can't understand how they can even be legal! But I wouldn't upgrade to ones with dotted DRL's, especially not if I'll be spending over £2k!! @Pauly, is your kit solid LED's, out of interest?
How much? I could be tempted with those. They will cover up all the square LED modules with a diffuser or something to hide them though won't they?I have gone a slightly different but almost equally expensive route (only because I can't help myself and wanted something different). Should not only be bright but also look fantastic.
00:28
The fog lights are led and I asked for them to act as a high beam flash so if I flashed someone to let them out it would be an instant light rather than what for the xenon to heat up. They are set to low beam and will work on high and low beam. So you will have all 4 on in the low beam and high beam them in high beam proper the shutter lifts on the xenon to give a full spread of light.I can't work out what half of things on the list mean, but particularly "fog lights in the inner reflector"? Does this mean using fog lights as side lights? Wouldn't that be too bright, and they're too high to legally be used as fog lights. I do like the idea of the projector lights.
He basically opens the headlights puts in a complete housing, lense ballast ect in place of the halogen lense/reflector, then alters the wiring to suit.( I have over simplified this massively by the way!)So they can fit xenons to the housing? That does sound appealing
I am hoping they will be with me this week and fitted the weekend after next as I am away in the caravan this weekend, I have a dipped grill and front badge to fit at the same time. I will of course post some pics and some night before and after pics. (sorry for the grill @Fish!)Over simplifying massively is the best way with me They sound amazing, when do you get them, interested to see what you think of them in real life use
