H & R 40 mm lowered - back is lower than the front
PJfamilyguy
My converted installed these springs during conversion and a week later the front looks slightly higher than the back.
Is this right ? I'm guessing so as the back has more weight in it.
I did question the converter and he said if you want it level you need to go full coilovers.
Yes the springs have been fitted at the front.
is there any way to tell if the stiffer ones are at the back ? is there a code on them to check ? I've checked underneath and I can see the blue coloured H&R springs are fitted at the back.
I think that the 2HA mark on the rear spring corresponds with the From 1561kg stiffer rear spring? Others will hopefully be able to confirm.
