Anyone else running this setup? Be interested to know your pressures.I've just had some 235/55/18 fitted and wondered what the go to pressures were please? I've been recommended 40-42 psi all round so far.
I've got a SWB T6.1 T32
Any thoughts people? Thanks
I run 40 all round.... similar set up to you. Does a few psi really matter? 40, 41, 42..… Unless you're sand driving etc...Reviving an old thread...
Anyone else run the same set up as mine? Interested to know pressures and what load you normally carry.
My van is empty most of the time although it has now been insulated/carpeted etc and had 4 seats fitted in the back.
Not sure if upping or lowering my pressures a tad will give me a slightly nicer ride too. I've been averaging 30mpg since swapping to these tyres/wheels - is that normal? I used to get closer to mid 30's I think.
I have TPMS so each time I get in the van I get a tyre warning which is annoying. I think seeing the pressures for my original Devonports is confusing me somewhat hence asking around in here.
Any feedback appreciated. Thanks!
Your TPMS issue may be because the Devonports had the sensors in the valves/wheels. What age/model is your van?Reviving an old thread...
Thanks for your reply.I run 40 all round.... similar set up to you. Does a few psi really matter? 40, 41, 42..… Unless you're sand driving etc...
Hey thanks for your reply. I took the TPMS out of my Devonports and moved them over to my current set up. The computer reads them OK but obviously the pressures are different so it throws up a warning each time. My van is a SWB 2020 T6.1 Highline Kombi.Your TPMS issue may be because the Devonports had the sensors in the valves/wheels. What age/model is your van?
The increased fuel consumption may partly be due to the difference in rolling radius with the AT tyres, which will throw out your actual mileage. Also the ATs will be heavier, requiring more energy to accelerate/slow.
Thank you. Wow that seems such a big difference to me. I find it strange that some of us were told 40psi all round and you were told 48.When my grabber at3 where fitted I asked about best pressure.
Was told 48 all around if I find them a bit soft add a couple of psi and if i find them a bit hard remove a couple of psi..
When i drove off I instantly noticed they where a softer more comfortable drive..
At present I run mine at 47 all round.
Really happy with the tyre choice..
T32 SWB.
Crikey they’re really high compared to others! Have you tried lower but settled on that in the end?My tyres are only 17's but these are my set pressures I run at although they do change a bit with the climate and driving.....tyres sit well and the van drives very well with these so no complaints.
I wonder if that’s because they’re 17’s? Mine were set by BM too but they set them at 40/42. Mine are 18’s thoughThese were set by BMVS when they did the mods, im happy with them at that..everything good.
