hi all anyone know where I could get a dash button for garage door
The dash buttons have set pictures on them so you would need to choose your preference on location/picture as they are all handed then wire it up to a modified fob
Never done one but I assume you would need to strip a fob and solder the fly leads onto the fob where the press button contacts are on the board
I can get the button and connector and make up some cables in the connector if it helps you get there ?
Alternatively you could get a small push button and drill into a blank and wire that up, would be a lot cheaper ?
Maybe using a switch like this, assuming you could use the centre as a common ground or power on the remote circuitObviously this will only work for single button fobs, if you have separate buttons for up and down then that will require a bit more thought
If it’s stand alone then should be able to, I think they only reproduce rf signals learnt into them
Anyone have a car with this system fitted and want to send me your vin number ? This is the kind of stuff I like playing with
Here's my remote. It has all those buttons, but you only use 1 button for up and down. Not sure why it has the others.
Plus I have plenty of blanks to use if an oem switch will slot in one of these.
Sorry to jump in on your thread @Stevemcc I had no idea this was possible, and the remote rattling round annoys the hell out of me.
Welcome to the forum by the way
