That's what VW Dartford told me too.As long as the place you use are VAT registered and use VW spec stuff you'll be fine.
Joke! Do your cambelt and water pump - about £650-750. It’s about £100 extra to do the front seal (and reputable mechanics will want to keep the van overnight to make sure it cures properly!) I can’t see the rest costing £1000, eh?!!Issues found
Brake fluid change required
Front make crank seal leaking
Fly wheel bolts leaking
Cambelt water pump requires replacement
been quoted over 2k to fix the above! Will be shopping around.
I would recommend a call to Oli and Simon at Bognor Motors. Well worth the journey as you can 100% trust them.Issues found
Looks like they have abbreviated your actual services.....probably should read 'interval inspection and minor (or major) service' etcHi, sorry to piggy back this thread, just hoping someone might be able to help with a servicing query. I bought my 2016 T6 in June 2020 from Listers VW and it came with 2 free services. In June 2021 when I took it for a service, I was told it had a 'big' service the year before and only needed a small one, so that's what I went with. I've just booked in again for this year's service and have been told the same - it had a big service last year and only needs an interim one this year (so essentially both of my 'free' services have been small ones). I've got a print out of my service history from VW and it only seems to show 'interval inspection' since 2017. Does anyone know the difference between the interval inspection and oil change service? Should it have had more than one oil change service?
Also, I had the DSG box serviced/oil changed last year but this doesn't show on the service history? Should it be on there?
Service history below:
Thanks dellmassive. Definitely no video, or test drive. No additional miles on the van. I've got an invoice and the maintenance list with everything ticked (including test drive ironically). But just wondered if there was any further paperwork with values etc on it.if its via main dealer -
you should get a video link emailed to you. ( showing your van and whats needed - or not )
and a call from the dealer or an email, asking for you to authorise whatever work needs doing.
then after an invoice with parts and labour breakdown.
