Fog light coming on with brake.
bootsam
Mechanical Engineer
Wifey just noticed that the front offside fog light comes on with the footbrake. Which seems a bit arse about face. Anyone seen this before?
Cornering?
Don’t they come on when maneuvering?
Cornering?
The van has had a recent cam belt and water pump, so there's been access on that side. I wondered if there was something electrical on that side. Rear cluster? Ill check for continuity at w/e.
Cornering light function. They will normally come on when indicating at low speed or turning at low speeds with headlights on. Should both come on when the headlights are on and you select reverse.
Shouldn’t toggle with the brake lights though.
I was unaware of this 'feature'. However only the offside one came on, but tbh I may be mistaken. I shall try it later tonight.
