It is a 4motion.
My local garage carried out a service and found oil leaking from the engine, so I took it to the dealer for investigation and they found the problem was that the bell housing is bolted to the engine and a hole goes right through and oil is tracking around the thread of the bolt. So they had to order a special bolt and drop the gear box and seal the threads and put it it all back together and replaced the flywheel (After googling this it is a common fault on DSG boxes) this was on the 19th Jan.
When I put the van in for it's first MOT which is due 16th Feb the garage called and said that it was in a right state and was lucky that the prop shaft hadn'tdrop down which could have been very nasty, which is lucky as I have just got back from a 350 mile trip.
I called the dealer and complained and they said was I accusing them for the problem, I said that they had the prop shaft out not me! Anyway they won't accept that it is their fault but will repair it under warranty.
