Extra door seals
jedkk
I finally got around to fitting the additional door seals at the weekend. The door does sound more solid when closed from the outside. I am finding it needs more of a pull shut from the inside though. I think I got them from vee dub transporters. Anyone else used them and think they make a differenc?
Here’s all the information you need :oops:
Fitted mine today. Have to say that it wasn't easy because the adhesive needs a warm day not a cold one! I resorted to superglue! Having said that I think they make a lot of difference to cab noise - I listen to speech radio at lot and it's much clearer now
Just fitted mine today. I find the door needs a real shove to close. Might have to play a bit more.
I fitted mine today on a cold day (8-9 degrees). You have to heat both the door and seal adhesive for.it to bind.
I used a heat gun on the highest setting which worked well, working a bit at a time.
