Electrical issue on my 150PS after flat battery. [Solved]
Martinsdub
Hi, I have an issue where my T6 will not start. It had a low battery warning on Saturday and I tried to start it, 2nd try it fired up for about 2 seconds and now the dash does not light up the electric windows are also not working. I and others (RAC & AA) have checked the small fuse box under the bonnet it has power as does the internal fuse box by gear leaver. All fuses in those have been checked and are OK. I have done a Hard reset on the battery terminals, still no Joy. I have also taken out the battery and looked underneath at the relays but unsure how to test them, they look ok and there is no evidence of scorch mark or burning smell.
any other ideas?
Thanks,
what voltage is the battery now? - have you fully charged it since it went flat?
can you take and post a pic of your fuse boxes here . . ( to compare fuses )
what IS working?
have you got a scan tool?
Hi, the battery is now out and on charge as am checking the relays underneath. Was at 11.9v when removed. Where can i share my ODBeleven download with you?
I'll get fuse box pictures uploaded soon
You can copy& paste.
Or
Attach files below.
Post some pics of the relay box.
The SA master fuse box is also under the battery.
Can you list what is working.
And list what's not working.
Maybe do a video on your phone and share a link to it?
Hi,
I will post pics of fuse boards and hopefully get a video of it not starting when it stop raining and need to get battery back in
Here is my ODBeleven download.
Code:
WV1ZZZ7HZKH034106 Volkswagen Transporter
OBDeleven data log
Date: 2022-01-16 10:27
VIN: WV1ZZZ7HZKH034106
Car: Volkswagen Transporter
Year: 2019
Body type: VAN
Engine: CXHA
Mileage: 7450 KM
01 Engine
System description: R4 2.0l TDI
Software number: 04L906056KG
Software version: 3771
Hardware number: 04L907445
Hardware version: H02
ODX name: EV_ECM20TDI03004L906056KG
ODX version: 004004
Long coding: 00254014432401090000
Trouble codes:
P157000 - Engine Control Module (ECM) disabled
static
U014600 - Lost Communication With Serial Data Gateway Module "A"
static
U101D00 - Power steering control module No communication
static
U015500 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
static
U016400 - Lost Communication With HVAC Control Module
static
02 Transmission
System description: DSG DQ500-7F
Software number: 0BT300046J
Software version: 5301
Hardware number: 0BH927711G
Hardware version: H11
ODX name: EV_TCMDQ500021
ODX version: 001001
Long coding: 0014
Trouble codes:
No trouble codes found
03 Brakes
System description: ESC
Software number: 7E0907379P
Software version: 0133
Hardware number: 7E0907379M
Hardware version: H06
Serial number: 62698000002160
ODX name: EV_Brake1ESCCONTIVN75XGP2
ODX version: 011001
Long coding: 557E409825658482AA760276A48821E679F100
Trouble codes:
B116831 - Steering angle sensor No signal
static
U112100 - Databus missing message
static
static
04 Steering Angle Sensor
System description: LENKW.SENSOR
Software number: 6R0959654
Software version: 0070
Hardware number: 6R0959654
Hardware version: H07
Serial number: 23091813470867
ODX name: EV_LWSKLOVW25X
ODX version: 005001
Long coding: 01
Trouble codes:
08 Air Conditioning
System description: Climatic-T5
Software number: 7E0907047AK
Software version: 0708
Hardware number: 7E0907047AK
Hardware version: H22
ODX name: EV_ClimaticT5
ODX version: A01003
Long coding: 0000000003
Trouble codes:
09 Central Electrics
System description: BCM PQ25 Max4
Software number: 7E0937090D
Software version: 0762
Hardware number: 7E0937090D
Hardware version: H82
Serial number: 8601 278180068
Long coding: A0AC393A0A61341193284F747CFB86750F84710F60CC69E0330400230840
Subsystems:
System description: RLS 190918 05
Software number: 5K7955559C
Software version: 0106
Hardware version: 50
Long coding: 0228EE
System description: DWA-Sensor 00
Software number: 7E1951172
Software version: 0104
Hardware version: 001
Long coding: 000000
System description: LIN BACKUP HO
Software number: 1K0951605F
Software version: 0008
Hardware version: H01
Long coding: 000000
Long coding: 000000
Trouble codes:
10 Parking Assistance
System description: PARKHILFE 4K
Software number: 7E0919475T
Software version: 0212
Hardware number: 1Q0919475
Hardware version: H03
Serial number: 32961821202141
ODX name: EV_VW75XParkAssis4K
ODX version: 001013
Long coding: 108108
Trouble codes:
13 Adaptive Cruise Control
System description: ACC Bosch PQx
Software number: 7N0907572C
Software version: 0211
Hardware number: 7E0907572
Serial number: 2909180453A12F
ODX name: EV_ACCBEGVW361
ODX version: 001006
Long coding: 00005000FE0779
Trouble codes:
15 Airbag
System description: VW10Airbag021
Software number: 7E0959655J
Software version: 0018
Hardware number: 7E0959655J
Hardware version: 010
Serial number: 003EK002NEVL
ODX name: EV_AirbaVW10BPAVW12X
ODX version: 001028
Long coding: 000000000000000000000000000000003231
Trouble codes:
U112200 - Databus implausible message
static
static
17 Dashboard
System description: KOMBI
Software number: 7E0920971A
Software version: 2030
Hardware number: 7E0920971A
Serial number: 00000000000000
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A05736
Long coding: 450B000300
Trouble codes:
19 Gateway
System description: GW-K-CAN TP20
Software number: 7E0909901
Long coding: 042307
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03710
Long coding: 000002
Trouble codes:
5F Multimedia
System description: MU-S-ND-ER
Software number: 5C0035680G
Software version: 0472
Hardware number: 5C0035680G
Hardware version: H41
Serial number: VWZAZ2U1592220
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Long coding: 065700013C00000011111101008808001F0100C6002001004F
Trouble codes:
61 Battery Regulation
System description: Batt.regelung
Software number: 7E0907534
Long coding: 030B1A73
Subsystems:
System description: J367-BDMConti
Software number: 4K0915181A
Software version: 1050
Serial number: 758852020021070701CE
Trouble codes:
Engine ECU cannot talk to the immobiliser in the instrument cluster and is therefore immobilised.
A fuse or wiring break. Most likely a fuse.
A thorough check with a multimeter across every fuse(no need to remove the fuses to test them) under the gear lever. Also, check fuses are in the correct slots and there is no empty slot with a terminal visible on both sides of the slot.
11.9v is reasonably flat, get it fully charged first and see what happens, you dont want to be chasing a fault that doesnt exist
Aux heater is 20a RHS lower fuse box under gear lever. Can you post a better picture. It's extremely likely that you have a fuse in the wrong place or missing in the upper fuse box. If you can see a metal terminal on both sides of an empty slot then there should be a fuse there
Links to my drop box for videos of it not starting, let me know if you can or cannot access it. If not PM me your email address and I'll send you the link via email
Ok, battery now @12.7v and installed all fuses metered as ok, power to both fuse boards pictures below. 1 fuse missing as AA friend lost in centre panel. Not sourced on yet but as is aux heater don't think it will stop it starting.
I'm fairly sure that 7.5a fuse above the two 10a fuses in your upper centre row should be in the slot above
Great, if you can see an empty slot with a metal terminal in both sides where the arrows are, then there should be a fuse in it.
