Dellmassive`s Camper Van Adventure
Nope. None at all.
In fact we haven't even used the EHU point once.
Ok double you turn...
Had a look at the alternative options.
Had a look at the combi units, ie inverter chargers.
Decided we don't need and 240v EHU in 96% of the time.
So decided to go with the inverter only option.
But 3kw ISH to convert the requirements.
And one that could be N-PE bonded, so we can make full use is the RCD protection in the consumer unit.
Decided that the 4% of time we need the EHU 240v in ..... It will be a stand alone battery charger clipped to the LB.
So after liking over the options...
I went for..
Yep, back to#team blue.
3000va, 2400watt continuos.
130% overload for 30mins
6kw peak starts.
N-PE bonded option.
But needs 90mm2 cable for 0-5m
Or twin 70mm2 - jeez
Recommended battery bank is 400ah.
So we have also ordered a second sb230 gen 4 to go under the passenger seat .. that gives me us a 460ah battery bank. From the guys over at @RoamerBatteries
Could you get the 460 s4 Roamer where my 230 upright is on the floor in the back wardrobe cupboard under a false floor? You'd soon sell a spare 230 SB... There's certainly space with your new inverter on its end..? That'd keep the Mrs happy with her hairdryer and kettle!
I've asked Roamer for a 460, and working with @RoamerBatteries to get one arranged.
We decided on a second sb230 for two reasons.
1. The inverter is too big fit under the seat.
2. We want to keep the 12v inverter to battery cables short as possible.... That 70/90mm2 stuff is £24 a meter!!!! We looking at £150 of cable and sundries just to hook it up.
3. We want to keep as much space in the rear cabinets for storage.
So it's twin seat base batterys and the 3kva inverter As close as possible to them... Then 240 out as needed via CU with RCD & MCBs.
Thing to remember with the cheaper inverters (and power banks) is the "UPS" function is a value add - they want to give you more functionality but don't want to add any more components.
If the output is floating and powering one single device it's generally safe enough, and that's how they expect them to be used. It's why they general have sockets (13 Amp UK or 10 Amp IEC) not hardwire terminals.
What those designs are not good for is hardwiring to distribution wiring or supplying more than one thing in the complexity of a van whose body is grounded for EHU safety.
So the simple rule is keep Inverter 240 and EHU 240 apart.
If you want ease of use go for the higher end stuff that as a transfer switch/relay for LN and a transfer switch/relay for PE to N bonding from the likes of Victron, Clayton, Mastervolt
I love the combi charger inverter we have on the narrow boat, they're not the best on space though as a lot of them use a low frequency inverter and use the same transformer core to do 240v to 12v and 12v to 240v. It makes them incredibly robust physically and electrically but it does mean you have a larger heavier transformer in them. Ours is now 20 years old and is in use most weeks of the year.
Check out this inverter deep drive....
Defo one for the geeks... It's faily data and tech heavy.
With love for Renogy and Victron.
So, 48v is the future?!!! He does secretly like that LiTime! Good watch, especially when the Mrs is away for the night in Liverpool with her mother!
48v is great, I run the domestic solar at that.
It would be good for a Crafter with loads of garage space.
But might be a squeeze in a T6, thought you could do it with twin 24v batterys.
2kw and under is fine for 12v
2kw and up, 24v or 48v should be considered.
I'm just playing devil's advocate and calling on the 12v 3kva Victron challenge.
more stuff ordered that i didnt know i needed . . . . .
getting one of these. . .
which then means i need one of these. . .
Slight side step .....
But me a the CA are discussing the van layout.
One thing we can decide on is the Porta potty...... Or more to point, where to store it.
Keep it,
Use it?
My idea was to keep it behind the RIB bed in the garage but.
But the CA wants it more accessable.
So what do you lot do?
Keep it in the back till onsite?
Then keep near the slider while camping?
We've seen loads of furniture units to store said potty in...... But again, where do your put it?
My Porta-potty (335?) lives at the back under the multiflex board (T5, Cali bench seat). Comes to the front at night, with its cover on. Goes back after morning coffee. Rarely used unless for a few days off-grid, or needed at short notice. Either way essential. My new LiPro4 you helped me on means I may be up to 4 days off-grid. Exploring more remote Scottish Islands. So will probably use it more.
I did without for years, and I think if you want to have the flexibility to stay in more varied locations where there may not be facilities, and venture to more remote places its worth the space, even if relegated in the "boot". I always decide whether to take it depending on where I am going.
Its one of those things that if you need it, you are glad, but if you dont use it, you resent the space it take sup 🤷‍♀️
We haven’t taken ours for years. I take a bucket with a lid but don’t use that either
Lol... Same, take a Comfort bottle (for night pitstops) and pee bucket (for extended day festival stops).
But the CA is not keen :sleep:
Keep it,
Use it?
I just leave mine behind the passenger seat, and use it as a seat when not in use. If I'm using the awning I stick it in the corridor bit between the awning and van
Off topic, but sort of relevant.
Many years ago I was driving home from work one new years eve, desperately trying to get home before midnight.
I was behind a Bedford CF, which shows how long ago this was, and paying it little heed. That is until a bottom appeared out the passenger window and proceeded to have a Forest Gump while the van was trundling along.
I was able to dodge the land mines, but this got me thinking that you folks could set up your turdis outside the van adjacent to the passenger door and pull the same trick.
