I contacted Renogy to see if the DCC50S is compatible with a mains battery charger (which I already have installed - looking to add the DCC50S + solar panel)
I got this response:
The DCC50S won't be able to detect if a battery is also being charged through another source hence we don't recommend using it at the same time with any other chargers as the battery may become overcharged. This means that you will need to disconnect your mains battery charger if the battery is being charged by the DCC50S.
How have people got round this before? It's suggesting that if you were able to isolate the solar panel when hooked up to mains then this would be ok or have I misunderstood?
Matt
Matt
