The lass told me my shaft was nice and straight..... and all the bolts get replaced
It's a long time since my lass told me that........The lass told me my shaft was nice and straight..... and all the bolts get replaced
As I said earlier, the engine SHOULD have been turned through 720 degrees by hand to ensure there was no clash of pistons and valves. There is standard procedure for any engine.Incorrect timing causing piston/valve contact on no 1 or 4 cylinder (either end of the crankshaft) which has taken the path of least resistance and broken the crank bearing bolts (and possibly bent the rod).
Probably did it on initial start up after reassembly (would have make a big bang) so timing not being checked after reassembly is the cause.
I expect the valves will be bent as well (probably all of them by now)
Your forgetting the average tech is just that not an engineer just spanner monkeysThe correct way to check a crankshaft for alignment in place is with a set of deflection measurements taken between set points on the crank webs with a dial gauge micrometer while rotating the shaft with or without the connecting rods attached (best done without and then again with rods connected)
I have no idea if VW use this practice or how tight the tolerances are on this engines crankshaft. In 43 years of working with engines, compressors and other rotating equipment I have never been in a position where I have heard ’the crankshaft may be a slightly bent but should be ok’. As @catfood12 has pointed out the other main bearing bolts have taken the additional load from the failed pair so all main bearing cap bolts need replacing. Also mentioned earlier was the possible reduction in oil pressure, almost certainly the affected cylinder would have had reduced pressure if the main bearing cap had been loose. The oil fed through the connecting rod lubricated the small end bearing / gudgeon pin, piston rings and cools the piston skirt and in some cases the crown.
You’re probably in the best place to get the work done but IMO they are making some assumptions and certainly not following some well established engine repair practices.
Not having worked in the ‘auto’ industry maybe I was unrealistic, if that’s the case no wonder there are so many FU’s.Your forgetting the average tech is just that not an engineer just spanner monkeys
I’m so glad my background is mechanical engineering, honestly I see so many techs that have not got a clue about measuring equipment of any kind and at no point would an engineer say the crank could be bent let’s give it a goNot having worked in the ‘auto’ industry maybe I was unrealistic, if that’s the case no wonder there are so many FU’s.
Not sure how agricultural this engine is but if it were mine I’d want it gone as soon as possible after the proposed VW repair, warranty or otherwise.
We punters are at the mercy of these companies and have to trust them to do their best.I’m so glad my background is mechanical engineering, honestly I see so many techs that have not got a clue about measuring equipment of any kind and at no point would an engineer say the crank could be bent let’s give it a go
Smoke coming from?Ffs. I drive home and all is good. Fill the van with tools and worktops. Drive to fill with Diesel just up the road and when returning home there's a noise and power steering gone. Battery light on with smoke pissing out. There goes my supposedly new auxiliary belt. Ffs. I need my van for work asap. They'll have to pick the f...... thing up now.
The belt. I can see it's shreddedSmoke coming from?
Not good they need to check that the clutching is working on the alternator when they replace itThe belt. I can see it's shredded
They said Friday they were replacing it. Reckon they didn't in the end. Can't move the f.... thing now. They will need to recover it. Do they do this ? Anyone know ?Not good they need to check that the clutching is working on the alternator when they replace it
I'm in their hands. I'm trying to find out what guarantees are in place after if any ?
Trying to blame me for going through water has pissed me off some what.
Unbelievable. Now I'm stuck again with a van full of tools and worktops. With a customer who's old worktops i have ripped out !As we've said it was never hydrolocked. That wouldn't cause this type of failure. More like too much nitrous!
Sorry to hear of latest dramas OP........
If they were planning on renewing the aux’ belt it’s highly unlikely they marked it’s direction when removing. So a 50% chance they got it right or wrong on installation.Can't see it on the list but they told me it was the reason my van wasn't ready Friday as they were waiting for one to arrive ??
So maybe they didn't bother
This is ‘bread and butter’ stuff for garages, if VW can’t do it without screwing it up.....They have it back and fitted a new auxiliary belt which has slipped off ?? So there's 3 technician's all over it.... ??
Unbelievable. What causes that belt to slip off ?This is ‘bread and butter’ stuff for garages, if VW can’t do it without screwing it up.....
I hope you got a detailed report of the work carried out and guarantees in place.
