Composition Colour Bluetooth Audio Name Freeze
david173
2017 T6 150PS SWB Kombi, work in progress...
T6 Legend
I have the standard composition colour headunit and often play music through the Bluetooth audio using Spotify on my phone.
However.... The name of the song doesn't change from the first song I clicked on when the song ends or I skip tracks or anything. It used to but now never does? Not massively the end of the world just really bugs me.
Anyone else have this? or know a fix? I tried resetting the headunit by long press of the on/ off switch but didn't help.
Have you tried to disconnect the main battery for a minute or so?
Reactions: mmi
I think so but ill check both suggestions and try again. Thanks both much appreciated!
It may be worthwhile resetting up the Bluetooth connection (go to Bluetooth on your phone and select forget this connection then set up again as new)
Also press in the off button on the headset and hold it down until it does a reboot.
Whilst your at it turn your phone off and restart it
Good luck
