Carista Errors T6 Caravelle
Ashypants
Evening,
Can anyone advise on the error codes below please :
ECU info obtained with Carista 376099 for iOS:
Engine
Part #: 04L906056KR
Coding: 0025401C437401080000 (hex)
Component: R4 2.0l BTD
Fault codes:
15560 Manufacturer-specific code
Transmission
Part #: 0BT300046A
Coding: 0014 (hex)
Component: DSG DQ500-7F
[No fault codes]
ABS
Part #: 7E0907379Q
Coding: 307E40986568847E0C76027DA68521D379F700 (hex)
Component: ESC
[No fault codes]
Instrument cluster
Part #: 7E0920980L
Coding: 770F010400 (hex)
Component: KOMBI
[No fault codes]
Airbags
Part #: 7E0959655E
Coding: 000000000000000000000000000000003043 (hex)
Component: VW10Airbag00C
[No fault codes]
Steering angle
Part #: 6R0959654
Coding: 01 (hex)
Component: LENKW.SENSOR
[No fault codes]
Headlight aiming
Part #: 6R0907357C
Coding: 0FC6020001000000 (hex)
Component: AFS-ECU
[No fault codes]
Parking/steering assist
Part #: 7E0919475N
Coding: 118109 (hex)
Component: PARKHILFE 8K
[No fault codes]
Heater & air conditioning
Part #: 7E0907040D
Coding: 0000000103 (hex)
Component: ClimatronicT5
Fault codes:
9581169 Manufacturer-specific code
Trailer
Part #: 1K0907383H
Coding: 0100000101000000 (hex)
Component: Anhaenger
[No fault codes]
Central electronics
Part #: 7E0937090
Coding: B8FC79BF0A61349393284F607EEB9FFCC0A4738960CD79E03204003F0860 (hex)
Component: BCM PQ25 Max4
Fault codes:
03303 Feedback Locked-Position rear-left
CAN network gateway
Part #: 7E0909901
Coding: 04230F (hex)
Component: GW-K-CAN TP20
[No fault codes]
Immobilizer
Part #: 5K0953234
Coding: 000000 (hex)
Component: IMMO
[No fault codes]
Adaptive cruise control
Part #: 7N0907572A
Coding: 00005000FE0779 (hex)
Component: ACC Bosch PQx
[No fault codes]
Auxiliary heater
Part #: 7E0963273
Coding: 4101 (hex)
Component: STH-T5GP2
[No fault codes]
Lane-change system
Part #: 7E0907566C
Coding: 030312 (hex)
Component: SWA Master
[No fault codes]
Battery regulator
Part #: 7E0907534
Coding: 030B1A73 (hex)
Component: Batt.regelung
[No fault codes]
Infotainment system
Part #: 5C0035680C
Coding: 06570001FF00000011111101008808031F0100C6002001004F (hex)
Component: MU-S-ND-ER
[No fault codes]
Suspension
Part #: 3C0907376A
Coding: 000180 (hex)
Component: DAEMPFUNGS-SG
[No fault codes]
15560 - EGR Sensor 1 - P046C 00 [108] - Implausible Signal - Intermittent
I'm not sure there is anything that can/needs to be done - unless there are warning lights on dash.​
9581169 - Positioning Motor for Center and Side Air Distribution Flap - B1232 71 [008] - Actuator stuck
03303 - Return message for left rear door closing condition
These two are probably easier to verify if they are still valid or just glitches from the past.
Thanks - all 3 were cleared last week and have come back. No warnings on the dash. The van is new to me - bought from VW so has 12 month Das Welt warranty - are they likely to cover all the above issues.?
Update having been into Sheffield Van Centre -
EGR valve - VW are aware but won’t do anything until engine management light comes on.....hmm.
Actuator Stuck - known issue will be fixed with a “software update”
Left Rear door closing position - Needs adjustment £52 for 1/2hr labour as not covered under warranty. They do say it’s the drivers side, which is a bit confusing as the error clearly says left hand side, which I would assume is passenger side....oh well they are the “Master Technicians” not me....
