i haven't got a finished project to show as I'm still working on various ways of achieving what I'm after, but I've been playing with these little devices TTP223 Mini Red Capacitive Touch Switch Button Self-lock/No-lock Module Arduino | eBay
and wanted to bring them to the attention of anyone who isn't aware of their existence, as I was.
They're dirt cheap but very versatile, being able to set the switch so it's either high or low on power up, and can be set to be latching or non latching with a simple solder bridge on the board. They can't handle much current so you'll need to use a relay, and it needs feeding 5v so you'll need to include a little regulator in the circuit, but they're tiny and cheap too.
So what's the big advantage? Simple, they will work when attached to the back of a switch blank and be completely invisible! They sense your finger touching the surface in front. No more aftermarket switch drilled through, you could use any blank, or in fact any plastic/textile surface in the van as a switch, maybe even print it's purpose and position on the front. You may need some sort of feedback to tell you if it's on or off, eg an led, if it's not going to turn on something obvious like a light, but they're perfect for anyone who wants to keep things stealth and factory looking.
You may be interested you may be not but I've been impressed by how well they work and thought they were worth bringing up.
