I used corrugated cable conduit. The type that is split down its full length. I wouldn’t dream of not protecting wiring. It can be cable tied to the body as there are often spare holes etc.
I have never noticed it rattling.
And, yes, I really wish I had put spare wires in !
Personally, i never use the use the stuff. I much prefer using nylon braided sleeve on exposed or unprotected cables and binding with a rayon fabric tape on longer looms.
If you do decide to use corrugated tubing you MUST tape the wires together before inserting them into the tube. Failure to do this can lead to insulation damage and subsequent moisture ingress leading to conductor corrosion.
