Mine just started misbehaving..... have taken black panel off but not sure how to remove that small holding bolt... is it a 5mm? (circled blue)The red arrow points to the black 3D printed arm. You have to remove the bolt to release it from the motor.
Its fiddly and a pain in the arse but doable without taking the dash out.
Theres another bolt around the corner (opposite the blue one) that was just loosened off, as to get to that you would need to remove more of the dash.
Hope this helps
View attachment 233613View attachment 233614
Thanks Tony, will WhatsApp you. Been struggling to get that motor off....2 and 3 won’t move as 1 which moves them is broken. The motor is held on by 2 5.5mm bolts.
I can supply you the broken part (pic attached) contact me on 07880620367
Regards Tony
Haven't been able to get a response.Finally got my heating controls fixed!
The issue was the white arm in the picture. One of the ends had snapped off.
Now replaced with a 3D printed one (black)View attachment 233109
I have spares so feel free to message me or email me (shepherdkai@hotmail.com) should anyone be in the same situation and need one!
Hi - I'm keen to help out. Coincidentally this part is on my list to design a replacement for after I've knocked out a couple of other designs I'm working on.Haven't been able to get a response.
Anyone else have luck in sourcing a replacement? Am located in Australia
Cheers JPR
