Right the suspension is off! Haven’t had a chance to clean it up before I went away so just took a picture in the box.
You get exactly what is in the original SoLow picture that I’ll add. You won’t get the top plates, drop links and the bushes you can see in the box. To be honest you won’t need any of that.
it’s in good condition and has prob covered around 1500 miles tops. SoLow’s run lush at max height (Around 100mm from standard) not so lush when you crank it down. A bit of weight in the back is also a good. Please be aware this is the T32 kit and your tyre and wheel sizes will definitely come into play.
£950
£950
