D
Deleted member 51993
Guest
Hi have recently added solar charger and battery monitor system to my camper and even though their is a split charge relay between starter and leisure battery i was wondering if i should fit a mechanical isolator, my reasoning for this is
1/ not sure it would or could but i dont want to take chance on damage alternator with solor power, solor power does have regulator and dont see why it is any differant from mains hook up charging starter battery.
2/ if starter battery is totally disconnected all solar power would then go towards powering kit and charging leisure battery ,i can then reconnect for when i am traveling to get power from alternator or reconnect if i have suspicions on starter battery level.
should i just let the split charge relay do its job or would an isolator really be required or aid me with off grid power.
many thanks in advance
