Lithium
Gordy1956
Now, electrics is not my thing,so i thought ask the experts out there, can i change leisure battery to lithium, setup now charges starter battery and leisure battery powered by solar panel works fine, no probs,can I connect an inverter as well for off grid use now and then , or is it more complicated then that. Cheers
You can change to lithium, but how simple or otherwise it may end up being depends on your current set up. Do a search or the forum, lots of info on these hallowed pages.
It would help if you can identify what the vehicle charger and solar charger and mains charger are, pictures may help.
Also why you want to change, do you want an inverter, if so for what purpose.
Pretty easy to burn your van out with 12v DC, if it’s not your thing I’d really advise getting a professional to do it.
