Autohaus control panel dead
crazymumtoem
Hello All, hope you are all keeping well.
I am new here today in hope that i might get some advice please.
We have a Autohaus VW T6 Conversion 2019.
In a nut shell my control panel is dead, I cannot turn on the fridge, the lights or the water pump. Whats worse is i have water struck in the tank. :o(
I have checked under the front passenger seat and the thingy under there seems to state that the battery is full and that the solar panel is working to charge. But i cannot get any life at all from the master panel.
I wondered if it might be a fuse. We have a breaker in the cupboard but that does not do anything when flicked up or down. So could it be an auto spade fuse. If so would anyone know which one.
Or might anyone know if somwhere like Halfords might be able to help.
Any thoughts would be greatly received as i do need to drain the water especially.
Thankyou in advance
Sorry this is a bit blurry as nabbed it of the net but can get a better one later if need be.
Can you post up some photos of the battery and wiring etc?
Take a photo of the fuse box before you start as a reference.
Remove one fuse at a time and check to see if the metal strip is burnt, replace straight away checking it is in the same slot that it was removed from.
Eventually you should find a blown (burnt) fuse if that is the cause, replace the fuse with the same value (A) that was removed. There is no guarantee that it won’t blow again if there is a fault, that is what it is there for.
Hello Thanks for the reply. I have to go out in 30 minutes, so i will have a look and see what i can photo, I can definatley see the battery and the fuses but not sure about the wiring. ill post back as soon as i come back to my computer. thanks very much.
Thankyou i shall do that shortly and update. i appreciate your help.
Hopefully you have the same fuse box as my Autohaus conversion- on the side of the cupboard with the mains trips.
Check these fuses, I can't say which one - I would have to start pulling each fuse and I am just on my way out! I'll get a pic with the fuse notations later if needed.
( what is the hurry to get the water out of the tank? )
Hey all thankyou. I've been through all the fuses and with torchlight have found one with a break. A brown no. 5. Dont know if this is my problem but just off to halfords. I will update shortly.
I'd like to Thank you all for your help. (Fingers crossed this is all it is.. )
Best wishes to you all.
X
Yes that's the one. Water has been in the beast for 4 months. arghhhh I usually empty asap but to be honnest I've Had this possible fuse issue for a while. I had removed them (fuses) b4 but didn't spot it first time round. I guess moral support is the key. You are all very kind and terrific people. X I'll update either Way later if the new fuse worked. Cheers again.
Water will be fine - it isn't as though it has been in over last summer's heat.
Thankyou everyone. all working now.
Nice new pack of fuses bought (mix pack as sugested) thankyou we are all systems go.
Next time ill look more closley ;o)
Thanks for the tip on the water that makes me feel a bit better..
Thanks again
Take care
N.x
Can I ask what the problem might be if you leave water in the water tank? I just part filled mine up over Christmas as I was using it for five days. Should I drain it when not in use?
On mine there isn't a facility for draining other than running the taps so there is always going to be some left in the tank, but then my tank is internal so not so likely to freeze. In the summer heat you have more chances of bugs developing if water is left for months on end.
Same. I used to have a T25 and I remember I used to sterilise the tank using tablets and fill it up and drain it a few times after it had been left over winter, but it had a drainage outlet so was easy to do. I guess you could do the same with the T6 but just draining using the taps...
Wow, just seen this link as I want to replace the control panel mentioned (display failure). Anyone know where I can get one?
PS, I've removed my water tank completely in my Autohaus Ashton (RIP Autohaus) . Never used it and now loads of extra space 😄😄😄
