275/35/20 tyre alternatives (T32)
helphelp
Hi, I am currently running Falken Azenis FK 510 275/35/20/102y I really like these tyres and have had no issues with rubbing on lock or anything else, these are a high performance tyre and fairly soft compound and not ideally suited to a heavy T32 van. I have bilstien B14 coil overs fitted and lowered to a very useable height and although the ride is firm it is not unpleasant, tyre wear is the only real issue as the van seems to keep going round corners extremely fast. :)
Someone has suggested to change tyres to 245/40/20 as more choice available better wear and cheaper, Are these the same rolling circumference I would be interested to Know what others are using.
Thanks !
The tyres you suggest is not suitable for a T32. They are only rated to 102 which is T30.
What width are your alloys?
I would recommend a 265/40/20 which are T32 rated
Also what pressures are you running?
Was not aware of the load rating being 103 the van has had 102 for the last 4yrs and the service and mot never flagged this up.
tyre pressures are 40psi or close.
The wheels are AC they are correctly load rated as I checked that but will have to check the width
