20” Supermetal Cell ideal tyre size
DarrylDunn
Sorry if this has been asked before.
currently running 275/35/20 front, 275/40/20 rears.
van is lowered around 60mm.
I don’t have any issues with rubbing on full lock but the roads where I live are getting shocking and I have had occasional rubbing when the suspension bottoms out.
im looking for recommendations on the ideal tyre sizes.
245/45 and 275/40 on a staggerd set with abit of rim protection aswell
Why the different sizes front and rear on rims that are the same width front and back?
What load rating is the van?
I’m surprised 275/35 rubs at all at 60mm down on those wheels. Can you measure from wheel centre to wheel arch at 12 O’clock position and let me have the measurement in cm or mm.
275/35 all round in the 9” wheel is ok, or you could try a 255/40 if you wanted something narrower and still load rated.
Smallest size that would work is 255/35 load rated budgets, but you shouldn’t need to go that small if the van really is 60mm down.
