Will these fit?
Freshtrax
Any ideas if these will go on a t6.1 start line currently on steel 16” wheels?
They’ve VW, 16” 5 holes.
Looking at the tyre on that wheel on the left that is a Hankook r28e which is a van tyre.
The wheels look familiar too but I can’t never remember the names of them all.
To be absolutely sure you’d want to see the codes on the back of the wheels look familiar- five studs at 120mm diameter, check the load rating is suitable etc.
My hunch is these are Transporter wheels and will fit. Sure someone else will know
Agreed, black painted claytons which are a factory fit alloy on transporters
@Freshtrax 16” wheels won’t fit on the front of any Transporter that has the larger 340mm brake discs. Make sure you use the correct OEM bolts not aftermarket alloy bolts.
