Which Slave on my T6
Bryanthetank
Please can you help me as I am confused, I have a T6 5speed gearbox and the slave cylinder has packed up?? Is this an external or internal slave cylinder? Thanks in advance
I believe the master cylinder is external and slave cylinder internal. Had it go on my caddy years ago tried the master first as was cheapest option but unfortunately was the slave and replaced clutch etc as precaution as was out anyway
Internal.
Edit: External, see post #7
The 5 speed uses an external slave cylinder with a separate release bearing in the gbox, 6sp uses an internal slave/release bearing.
There is no cable used Ricardo T, only hydraulic.
The crunch is something we've come across, more so on caddy rather than transporters. Although given that you say it does the fault in first, I would be looking in to an issue with the clutch rather than the box itself. Would be surprised if it was covered under warranty (whether VW extended or a non franchise warranty)
