It's lookng like the sweet spot for solar is 100-300 watts of panels. Depending on demands.
The base kits always come with a PWM solar charger. It's recommended to upgrade that to a MPPT for a better conversion of solar energy.
One or more 110Ah deep-cycle leisure batteries are common.
We used a Colman 12v fridge on a 110ah leisure battery and it killed it in 24hrs.......
so how long your setup will last will depend on how much kit you have connected and drawing power...
During the summer months a decent solar setup should be able to replace the power drawn from your leisure batteries and keep you self sufficient.
If you need more run time for power then add another leisure battery. . . . . .
If the battery bank is not being topped up enough during the day in summer then add another solar panel.
Led lights and USB are low power . . . And will last a long time.
240v inverters with kettles and heaters plugged in will draw loads of power and drain your batteries faster.
I've gone for a mobile solar setup that I can take with me on trips and just deploy and plug in when Onsite. . . . I went for 100w Renology Suitcase panel and victron MPPT charger. And 2x 110ah leisure batteries..
I'll be adding another 100w Renology panel for next year to give 200w solar.
That should he enough to keep the batteries charged up.
