On the road….Is that after a car park burn out or were you driving on the road like that!?
T32 4motion buddy currently on Bilstein b14sWhat suspension do you have?
Around 60-65mm. Definitely more wear on the inside than the outside.Maybe its just me, but that looks reasonably even wear across the tyre. Mind you its well below the legal limit all the way across. I've seen photos of far more uneven wear than that.
How low are you on the B14s?
Yes, I can see there is more wear but not massively like some I've seen. Did you have it 4 wheel aligned on a Hunter machine?Around 60-65mm. Definitely more wear on the inside than the outside.
Yes did the hunter alignmentYes, I can see there is more wear but not massively like some I've seen. Did you have it 4 wheel aligned on a Hunter machine?
And what was the error? Toe or camber?Yes did the hunter alignment
About 6kHow many miles did you get out of them?
That's not good.About 6k![]()
