Powerflex rear bushes
Mickhar
Hi Guys finally got around to fitting the rear powerflex bushes , which involved disconnecting the handbrake cable , abs cable , air pipes , brake hoses and height sensors . Removing the trailing arms bolts came out fairly easily i then used a trolly jack to support the weight and lower them to the ground . Removing the old bushes was relatively easy using the extraction tool i bought from ebay . The new bushes have the possitions moulded into the silicone so you cant really get it wrong, but the inner bushes on each trailing arm have notches which locate into the hole inside the arm so these are a little harder to fit .
If anyone is thinking of doing this job i will probably sell the extraction tool as i have now replaced all the bushes including the arb .20250922_121630.webp20250922_121636.webp20250922_121636.webp20250922_123207.webp20250922_132723.webp20250922_132723.webp20250922_133045.webp20250922_133257.webp
