VW T6 error 16110+16114
suprrr
Hello, got one t6 with low fuel pressure error codes, changed all the injectors, hp pump, and rail with lines complete with regulator and high pressure valve.. and still the same.. measured the low pressure pump to deliver around 5bar. So I assume that is OK. Now im out of ideas... anyone had the same issue that can shine some light over the issue? :)
What's the lube data port plugged data show?
Have you got access to vcds?
Assume the engine is a non-runner?
Maybe start with posting a full VCDS scan. and then MMI will probably want a bunch of engine Blockmap recordings to determine wheer the issue could be.
Hello, engine runs good at idle and under 2000rpm, when pushing for kickdown it goes to limp mode. Have 1300bar high pressure. think its a little too low...
Good that it is still running -
At what revs/loading was the pressure reading taken at ?
