Yes, I could have plotted but it was all just dead flat.@mmi can you plot his data in a graph?
The data as of post#17 would be different...
Yes, they do run. Also would flag a fault if the sensor is disconnected.@mmi do these engines run when the air flow sensors are disconnected? I know some engines (Renault i think) will refuse to start when disconnected. Having said that, I'm pretty sure I've had them disconnected in the past and they do run.
Could be a red herring but could be worth investigating...
If the high-pressure fuel pump (HPFP) fuel pressure regulator (N276/N290) on a VW has no power (de-energized), the valve defaults to an open position.
In this open-circuit state, the HPFP cannot build up internal high pressure. Therefore, the fuel pressure in the high-pressure rail will only be equal to the fuel pressure provided by the low-pressure lift pump
Therefore, with only 7.6 volts on terminal 15, perhaps this would cause the regulator to be open and therfore no fuel pressure other than from the lift pump? In saying that according to the block map it is showing "Regulated operation via pressure control valve" so possibly working OK.
Maybe another blockmap as suggested by @mmi will give us mor
sgree
Id agree. I said that in the post above about the pressure regulator valve.
It definitely needs checking for power..
A wise old mechanic told me once that "pressure is not created by the pump, that just creates flow... It's the resistance to follow that causes the pressure"
Wise words , if the valve is open. Then no pressure, .. defo voltage check required.
Post in thread 'VW T6 No start but cranking' VW T6 No start but cranking
Ah, looks like we getting somewhere.voltage readings are 0 at the regulator on cranking 0 too
I checked fuel pressure after the HPFP and showing over 300 bar on the gauge but there is nothing at the rail even with injectors pipe connections blocked
I will check wiring to the pressure regulator tomorrow
Thanks for the log. Below GREEN=good, RED'ish=badHi All
there was brand new HPFP pump fitted with cambelt ( Delphi with same part no )
Fuel pressure sensor and fuel regulator was changed as precaution as well ( fuel pressure original VW , fuel regulator Delphi )
I love these charts, it makes the data so much easier to visualise and understand.Thanks for the log. Below GREEN=good, RED'ish=bad
It seems the ECU tries to drive fuel pressure regulator valve (IDE07822) when cranking as expected.
However, the logged current (IDE05632) should peak to 500-700 mA to build up the pressure when cranked. Now nothing happens. Also at the rest (RPM=0) the current should be about 100 mA.
Is the regulator OEM part? How about trying the old one?
2022-03-14-A
These?@mmi if you get a chance can you screenshot the schematic for the valve,?
I'll be back in the office tomorrow evening off not.
Or anyone else?
These?
I'm afraid that's not correct for MY17 CXHA engine - seems to be for CFCA engine.J623 engine computer controls it, looking at that schematic.
Fuel Pressure regulator was changed for new one ( Delphi ) to try eliminate that possibility
