ENGINE LIGHT ERROR
ERCINOU
Hi to everybody, i have a vw T6.1 2019 2L 102 HP, 145000 km.
The engine error light turned ON for two days than OFF. A few days later it is ON again.
I connected the diagnostic DELPHI and i have the message " LOW PRESSURE CYLINDER 3".
The engine works very fine, any start perfect and nothing wrong appears : exaust pipe smoke, temperature, mecanic noise or so.
Comsumption is still perfect, 6,8 L/100 Km.
I don't know if is a problem that th engine goes over 2500 RPM very rarely due to my way of driving.
I am wondering about the engine itself or the "pressure sensor" if there is one and how the mesure is made to display the mistake.
Thanks for read me.
Regards. Aurelio.
  • Sad
There is a cylinder pressure sensor built in to glow plug no.3 - this is likely to do with that sensor.
Ideally, more info / description on the fault code is required to investigate further. I.e wiring / or the actual glow plug.
Hi to all and thank you very much for info, this helped me to find the issue. In fact, the glow plug 3 is dead.
Kind regards.
Aurelio.
