VW T6 No start but cranking
ghosthd80
Hello to every one !!
I have massive problem with VW T6 no start ( Big bottle of whisky waiting for the hero who can help to solve the puzzle )
Transporter come with EGR flooded with water ,compression checked ( 300 PSI across )
changed HPFP with fuel rail regulator and sensor and new cambelt with water pump
van is cranking but no start VCDS keep saying Low system voltage ( battery is new and on charger as well )
cranking speed is good no fault codes
Fuel pressure is only 12-15 bar ( why ? )
Ground points was checked and clean
I'm loosing my mind over it
can anyone help please ?
any help much appreciated
First thing is do a full reset...
Ger a charger on there... For a full 24hr charge up.
Run a new vcds scan and post on here.
Did it run ok before?
What changed?
See here for rail pressure......
Check for cam & crank signal.... Timing belt changed.. so it's it in time?
Do you get rpm signals?
Why was water in EGR?... Leaky cooler?
Does it fire up on starter fluid?
(1) Please post full VCDS Auto-Scan
(2) Please make a log of the following.
Ignition ON
VCDS > Select > 01-Engine > Adv. Meas. Values
Tick data items
IDE00021 Engine speed​
IDE00182 Camshaft adaptation intake bank 1: phase position​
IDE00347 Air mass: actual value:​
IDE00352 Main injection: duration of activation​
IDE00407 Rail pressure regulation: status​
IDE00412 Starter control: terminal 50​
IDE00416 Starter control: terminal 50 feedback​
IDE07742 Cylinder head: pressure sensor 3 bank 1: raw value​
IDE07744 Particle filter: air pressure sensor 1 bank 1: raw value​
IDE07818 Fuel high pressure sensor: actual value​
IDE07824 Tank-internal presupply pump 1 bank 1: activation​
Tick
Log > filename > Start (the logging - IMPORTANT!!!)​
Crank the engine (4 seconds is sufficient)​
Stop (the logging), etc.​
The result files are saved into directory C:\Ross-Tech\VCDS\Logs
Please post the log files
Code:
Thursday,02,April,2026,07:34:10:35423
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20260227 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH186269   License Plate:
Mileage: 237090km-147320mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZJH186269   Mileage: 237090km-147320miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KL    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6166
   Revision: 23002001
   Coding: 00194014431401090000
   Shop #: WSC 02762 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KL 004012
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 01585CAAA181AFF2815-8054
   VINID: 9E606AAAA1D8A9A60120608624951BDD24
2 Faults Found:
27277 - System Voltage
          P0562 00 [00100011] - Too Low
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 237097 km
                    Date: 2085.01.30
                    Time: 00:01:30
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 13  C
                    Intake air temperature: 6  C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 11.960 V
                    Unlearning counter according OBD: 40
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -0.34 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.004 bar
                    Absolute intake pressure: 98 kPa abs
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 4
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
27168 - Heater Support Pump
          P16C6 00 [00100011] - Running Dry
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 237097 km
                    Date: 2085.01.30
                    Time: 00:01:47
                    Intake air temperature: 7  C
                    Voltage terminal 30: 11.984 V
                    Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                    Heater support pump 1 bank 1 primary circuit: activation: 0.00 %
                    Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 10.00 %
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 61458000000091
   Coding: 557E4098256A8484AA77027CA48B21E679F100
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3FDC9A5297F51902B71-806A
No fault code found.
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 11041813470419
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA22756D07FD00AFC7-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 73B40662EB3D8D62839-8026
1 Fault Found:
9481200 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 237097 km
                    Date: 2026.04.02.
                    Time: 00:02:13
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 144182005
   Coding: A0A4303A0A613431922049542C2B8C540F00708F60464D60330400220800
   Shop #: WSC 02762 022 1666578
   VCID: 2B04DE02730D95A20B9-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU023051881432082
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU023051881432916
   Coding: 0400A0
   Subsystem 3 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Coding: 000000
   Subsystem 5 - Part No: 7E1 951 172
   Coding: 000000
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32931812802820
   Coding: 11800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 43D496A2FB1D7DE2D39-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 0905180452B350 Dataset Number: 7E0114v____ 0009
   Coding: 00004800FE1779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 3632FF76B8CFD84A647-8062
4 Faults Found:
1380 - Internal Fault
          B200F F0 [00001000] - -
          [FAULT_ADC_VZ_BELOW_RADAR_OPERATION_LIMIT]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 25
                    Reset counter: 167
                    Mileage: 237097 km
                    Date: 2026.04.02.
                    Time: 00:23:03
                    Control Module temperature: 23  C
                    Voltage terminal 15: 6.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
15360256 - Component Protection
          U1101 00 [00001000] - Active
          [FAULT_ATP_IKA_ACTIVE]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 237097 km
                    Date: 2026.04.02.
                    Time: 00:00:15
                    Control Module temperature: 22  C
                    Voltage terminal 15: 11.3 V
1088 - Databus
          U1123 00 [00001000] - Received Error Message
          [FAULT_CIS_GP_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 167
                    Mileage: 237097 km
                    Date: 2026.04.02.
                    Time: 00:01:20
                    Control Module temperature: 18  C
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VMON_VZ_LOW]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 8
                    Reset counter: 167
                    Mileage: 237097 km
                    Date: 2026.04.02.
                    Time: 00:23:05
                    Voltage terminal 15: 7.6 V
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK001CJRA Dataset Number: 7E0003V____ 0905
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02164 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D20E05A9DF90B12A5D-8068
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Serial number: 00000000000000
   Coding: 450B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 3A2AEB468CD73C2A80F-806E
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 688E610EA27B7EBA26B-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1107
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: 6A8A1B06BCF74CAA30F-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 14051800011226 Dataset Number: V03935266VJ 0001
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E02D716409FE08A2C7-807A
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 330B7A73
   Shop #: WSC 02762 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 7588570000180524031E
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000480493506
   Coding: 410D000103000000
   VCID: 323AC3665427C46A48F-8066
End----(Elapsed Time: 01:40, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------7 Faults Found-------------------------------
Have you tested the Terminal 15 Relay (power with ignition on)
It is only shwong 7.6 volts.
new fault code emerged
16197 - Starter Control; Returned Message
P3053 00 [01100000] - 50 Short to Ground
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 237097 km
Date: 2085.01.30
Time: 00:13:41
Engine speed: 123.75 /min
Coolant temperature: 14 C
Intake air temperature: 13 C
Voltage terminal 30: 11.921 V
Starter control: terminal 50 feedback-Terminal 50 on CAN: not active
Starter control: terminal 50 feedback-Terminal 50 CAN valid: active
Starter control: terminal 50 feedback-Terminal 50 via cable: not active
Starter control: terminal 50 feedback-Starter relay: active
Starter control: terminal 50 feedback-Starter operation read back wire T50Ret: not active
Starter control: terminal 50 feedback: 24
Starter control: terminal 50: not active
data attached as requested
The fuel pressure (lack of) is the issue. The ECU does not even try to fire the injectors without proper fuel pressure.
Does the lift pump actually work? Do you get fuel into the fuel filter?
Can you hear the pump?
See the test below
Please use Advanced Measurement Values for this ECU - not the Measurement Blocks. Much easier :thumbsup:
Hpfp is new
It was changed as a precaution ( scratches was visible on the shaft)
Strange 🤔 - especially as there is not even slight increase in pressure when cranking
Please make a log (as described above, use selection of Advanved Measurement Values) of the following - just to trace fuel pressure regulation circuitry
IDE01378 Fuel high pressure: control deviation​
IDE05632 Fuel pressure regulator valve actual value​
IDE05633 Valve for fuel metering: feedback value measured​
IDE07807 Fuel temperature sensor 1: B1: raw value​
IDE07819 Fuel high pressure sensor: unconditioned voltage​
IDE07821 Fuel metering valve: activation​
IDE07822 Fuel pressure regulator valve: activation​
Is there deffo fuel getting to the hpfp?
Maybe crack open the rail pressure valve to bleed air.
Or even the hard lines to injectors to bleed through any air.....
Hpfp won't build pressure off it's airlocked.
It's obviously a fuel problem, ... So let's follow the fuel path from tank to cylinder methodically.
You have checked fuel flow from tank to filter.....
Now let's check at each point after that.
Fuel definitely getting to the hpfp,
Fuel pressure check and flow test done at Fuel filter outlet (all correct )
On cranking Fuel coming out from Fuel rail outlets when connection is loose
Honestly this engine drives me mad I can't sleep properly because I have to solve this puzzle so bad .
Is anyone think no coolant in the system could make a difference?
Code is triggered "pump running dry"
Would that prevent ecu to close Fuel pressure regulator ? ( to protect the engine)
Current state attached
Not sure....
Possibly. Worth a try.?
you have fuel at the rail....but it's not raising pressure.
Could the HPFP be faulty?... What comands can we check with hpfp to get it to raise pressure.
The fuel rail pressure regulator?,.... Have you tried disconnecting it to see if it makes a difference?
@mmi can you plot his data in a graph?
We still saying that he has no rail pressure?
I know that when I had the new CXEB long block engine fitted.... The techs took ages to get it to fire .... They had it turning over on and off for almost a minute....
Reactions: mmi
