Hi,
And thanks
@Kurien Philip and
@andys for your reply.
@Kurien Philip: Did you get a VB workshop manual after your VB installation and all removed parts?
To complete my previous question. In this video we can see:
1) The step "
Shorten the original rubber stop support to 10 mm"
=> Is it easily possible to go back to the original suspension after that?
My understanding was we can keep all removed part to do it if necessary)
2) Here, the reseller's technician seems to move back the fuel tank to drive some air lines or sensor cables behind it. It's more secure, but not sure that all reseller's technician will do it.
=> Is it a mandatory request of the VW certification?
=> Is there a VW tracking sheet that reseller's technician must follow?
=> In the followed thread we saw that VB Air Pump for Suspension has been connected directly to battery's negative. Is it correct? Not sure...
Starter Battery Wiring - VW Disagreement | VW T6 Transporter Forum (t6forum.com)
3) After I noted this interesting view…
… with the emergency valve set option and some unknow plugs which disappear after …
But on the second view the air cables are colored and not on the first one, so it's a video building and my questions are:
=> Is the emergency valve set position an VW request?
=> What are the other plugs? Are they VB Airsuspension parts?
4) After the most terrifying view, the disassembly of the dashboard for the speed signal if my understanding is good. I was not aware of that…
=> Could you confirm that?
=> @T6 administrators: if possible, is it possible to get the current VB workshop manual?
Thanks to everyone for any help
