Upgrading the Factory Leisure Battery set up (+ additions)!
As to changing the cable I think 16mm2 would be preferred, but if you plan on running at 30A charge most of the time arguably that's what your existing system has been doing and I assume no signs of any heating issues?
If you wanted to regularly charge at the full 50A I'd be much more inclined to run a 16mm2 while you have everything in bits anyway.
You have to account for the loses in DC-DC conversion so I'd normally expect the manufacturer to specify a higher input fuse than 60A for a 50A charger.
I'd suggest running it at 30A (in software/settings) for general use and only using 50A when fast charging is really critical, it's a lot kinder on everything if you don't need it charged RIGHT NOW.
The SA3 terminal is vacant so I may be better off running a 16mm cable now. Does mean getting that poxy e-box cover off again though
One of the advantages of the 6.1 electrics is that additional blade fuse box on top.
But then I suspect that bites you back when you have to juggle a fresh battery in
This is my current set up in my 2018 Caravelle, a mess of wires of a Factory specced Eberspacher Auxiliary air heater and 2nd battery, plus a few extras fitted by the previous owner, all under the passenger seat:
This is the wiring diagram as it sits:
I've got the standard split charge relay, and the 75Ah AGM battery feeding 3x 12v USB ports and the air heater, from factory. It's also feeding an Anderson connector, basic battery monitor, and 12v socket on a passenger seat board:
And a 12v socket and dual USB socket on the drivers seat board:
Also under the driver's seat is a 240v consumer unit with hook up lead under the bonnet, going to a Victron IP22 12/15 1 output charger and a 3 pin plug under the driver's seat.
As it is, with the limitations of the SCR, my 75Ah AGM battery only has 22.5Ah of usable capacity.
I'm currently building a kitchen pod which will have in it, a CRX50 fridge, plus some LED lights, a couple of USB ports and a submersible pump for water.
So, I want to upgrade my current set up slightly - mainly getting some proper battery monitoring via a Victron BMV-712, and as they seem to be short on stock until march I'll probably try and pick up the new Victron XS 50a B2B charger.
Also adding (moving) the Anderson connector on the passenger side to the drivers side so I can use that as a single connection for my kitchen pod.
This would mean I'd have a whole 37.5ah of battery capacity at my disposal!! And, crucially, I'd be in a much better place to be able to upgrade to a LiFePO4 battery and/or add solar in the future.
I'm aiming to be able to go away for 2-3 nights and I'd like to have a fridge and lights/water for that time. I know I'll need either solar or a bigger battery to really do this properly without having to drive, however I'll be driving a bit on a normal 2 or 3 day trip so should be ok for now.
So, proposed set up is below:
The main changes are a master 150a Megafuse and isolator switch on the LB.
Positive connections all going to a Busbar under the passenger seat.
DC-DC Victron charger in place of the SCR
Victron BMV-712
Factory fuse box etc tidied up under the passenger seat so that if (when) I upgrade to a LiFePO4 battery I'll just be able to slot a seatbase battery in! Yeah, ok... maybe not quite that easy!
Then under the driver's seat:
Fusebox for all the auxiliary non factory stuff, so the USB, 2x 12v sockets and the Anderson connector.
A negative Busbar for the above auxiliary stuff, and the battery charger.
I'm probably missing some fuses, bearing in mind the longest run of any wiring will be between the front seat bases.
And I'll need to check on what size wires I need, hopefully I'll only need 3 sizes: big beefy boy for the negative battery connection to the BMV712 shunt and to the chassis ground, and the same size for the Megafuse and isolator to bus bar. Then some 60a rated stuff for the DC-DC charger and Anderson connector, then 20a rated stuff for everything else.
Hi TallPaul, thank you so much for your thread. It has really helped me a lot.
I also have a VW factory fitted auxilliary battery in my T6 4Motion and am wanting to replace the VW SplitChargeRelay with my DC to DC from Atempower.
Is it correct that in my photo below the black block that has 100 written on it is the SCR and the black wire coming out of it is for the ignition signal and the thin brown wire is earth/negative.
Thank you.
Thank you.
Correct!
The brown earth will go back to the earth stud in the seat base. I use the black signal wire into the remote port of my Orion XS 50, works perfectly.
Great thread this , can’t believe I hadn’t found it previously.
I’m in the process of changing my factory leisure set up in my 6.1.
I’m installing Roamer 160ah & Orion xs 50 .
I spent some time last night reading the Orion manual . 43 pager !!
My questions if I may ask regarding the engine signal . Looks like it’s an option to wire it into the Orion . This brown & black connector pictured below was plugged into the SCR . I assume this is the engine run signal ? If I don’t use it will that be an issue ? If I do which wire is it ? Can you advise ? IMG_2132.webp
Also I have mounted my Orion xs on ply . Slightly concerned about heat behind it . Should I try and slide something else in behind ? Or nothing to worry about?
This is my progress , needs a good tidy up, only thing you cannot see is the cable from the starter battery , I have connected a 60 amp midi fuse at the connection then 16m2 cable to dcdc .
Actually one last thing if you can help , there is a 6mm +cable from the starter which is crimped to a short wire then into a 10amp fuse block . I would like to tidy this but don’t want to upset anything. Another pic below I can’t make sense of it ! IMG_2127.webp
Not sure on the 6.1 set up but that looks like the ground (brown) and engine run signal (black) wire. If so then you can use the black into the Orion.
My kit is mounted in plywood but I have painted it all in heat resistant black paint. Looks better than bare ply too.
My kit is mounted in plywood but I have painted it all in heat resistant black paint. Looks better than here ply too.
Nice one sounds like a good idea regarding the paint , i have some stove paint i can use . I'm very tight for space so i was thinking i might need a bit of cement board instead which i cannot fit in . The XS is already just touching the battery which is not great .
For the Orion mounting remember to think about the airflow over the cooling areas. It's mounted in the best orientation already but think about how to keep the areas the air flows in at the bottom and out at the top clear to help the circulation, maybe drill some holes in the ply to let air in to help.
Thanks @roadtripper i have actually ordered the below vent which I’m drilling through the seat base .
I ended up taking the ply out . Putting a bit of thinner 9mm ply with 6mm cement board on top . With a vent through the middle behind I’ll be
Happy.
All finished , minor tidy up tomorrow.
Setting up the Orion was easier than I expected. I’m going to put a battery monitor on the starter so I can see that the Ablemail is doing its thing . Took way longer than I had planned. IMG_2162.webpIMG_2163.webp
Looking good. If you're doing a final tidy consider putting some PVC or Mesh sleeving over this section of what looks like your main battery cable (possibly before the main fuse?)
Looks like there is a bit of a chance of fretting and wear against the rib on the seat frame or the bus bar, both of which are grounded.
Plus point is if there is a bit of chaffing it's much easier to swap a new bit of sleeve in rather than changing the cable run.
I am reading all this with envy, I would love to be confident to attempt something like this, but no way that I will ever be.
My 2020 T6.1 conversion came with a factory installed LB under the passenger seat 75a AGM, which i believe is charged via VW split charger. I would really like to have it changed to a lifepo4 Fogstar 105ah.
Las year we went to France and Domestic fridge stopped working on the 3 day as it was well warm and working overtime. So as @Dellmassive suggested that Lithium is the way forward. It's fine when on EHU but off EHU it's a push.
The only solution for me would be to get it done by someone who knows what to do in this respect.
Does anyone know or would be able to recommend where it can be done around Mid Wales/North Wales/Shropshire. To be honest I am willing even to travel anywhere as far as Southampton (I can visit my aunt while there).
If you're heading to the south then forum trade regulars @Absolut5 and @BognorMotors are in range.
And absolutely nothing bad about doing your research but deciding it's out of your comfort zone. Your more informed about what you want and what your needs are.
I have a rule of thumb at 30A - circuits above that I'm likely to ask someone who works with that sort of stuff everyday to do the work, if for no other reason they'll have better pro grade tools.
