Tyre Width?
T6180
T6 Legend
I've managed to purchase some new allows, they came with 255/40/20 & 285/40/20 tyres.
The kombi is lowered on B14s
I'm aware I need to change the front set as they are only load rated to 101Y, so the replacements need to be 265/40/20 104Y
The rear set are 285/40/20 104Y, can someone advise if 285 is to wide for the rears and will rub on the sliding door when opening?
How wide and what's offset (ET) of your rear wheels? That will determine how far out your wheel and then your tyre will stick
As said above, i run 275 on a 9.5" rear ET35 + 10mm spacer and there is no issues
I'm going to be running a 9.5 rear.... I suppose the only way to find out is to fit them
Can't see you having an issue..... I've got a decent amount on clearance
@YESBOY you won't be disappointed with the b14s...the handling is so much better, less body roll but no compromise to comfort and less bouncy bouncy .....kombi feels planted and more car like.
I have the chance of changing offset so should I look to change slightly ?
I want them quite flush on rear but without any rubbing issues
  • Equivalency table
    Rim width Minimum tyre width Ideal tyre width Maximum tyre width
    5,0 Inches 155 mm 165 or 175 mm 185 mm
    5,5 Inches 165 mm 175 or 185 mm 195 mm
    6,0 Inches 175 mm 185 or 195 mm 205 mm
    6,5 Inches 185 mm 195 or 205 mm 215 mm
    7,0 Inches 195 mm 205 or 215 mm 225 mm
    7,5 Inches 205 mm 215 or 225 mm 235 mm
    8,0 Inches 215 mm 225 or 235 mm 245 mm
    8,5 Inches 225 mm 235 or 245 mm 255 mm
    9,0 Inches 235 mm 245 or 255 mm 265 mm
    9,5 Inches 245 mm 255 or 265 mm 275 mm
    10,0 Inches 255 mm 265 or 275 mm 285 mm
    10,5 Inches 265 mm 275 or 285 mm 295 mm
    11,0 Inches 275 mm 285 or 295 mm 305 mm
    11,5 Inches 285 mm 295 or 305 mm 315 mm
    12,0 Inches 295 mm 305 or 315 mm 325 mm
    12,5 Inches 305 mm 315 or 325 mm 335 mm
The chart shows its to big but I've spoken to lots of tyre shops over past few weeks and I've gone with 275 on a 9j rim every body said it will be fine ?
Let's hope so at £250 each !!!!
I just hope mine don't hang over to much I just needed 275/35 to get load rating !! Maybe 265/40 would of been better !! All ordered now !!
