I've had this T6 for about 5 months now. Whilst driving last month It suddenly acted like the key had been taken out the ignition, lost engine, MFD, power windows e.t.c only thing left working was hazards, headhunt, interior lights, stuff that still works with no ignition. Breakdown found a 10A fuse in slot 26 to be blown, suggesting it was for the body control module. Replaced with another 10A and then it was fine for 800 miles, until it did it again today out the blue. Again fuse 26. Replaced and it's working again. I can't work out what is causing it to pop, the fuse diagram on this forum suggests it's rear wiper / washer but the Haynes references the AA used said it was control module. The suspicious piggy bagged fuse I can only assume is for the 12v socket in the back that was an aftermarket install years ago.
worth noting these issues only started after the door speakers were replaced, but the electrician who installed them said he didn't go near the fuse box, they are direct replacements no amp. Image shows the fuse that went. It's a 2015 T6 t28, not sure if that makes a difference.
P.S it's pretty scary to just lose engine, power brakes, and power steering when you're driving at 50mph in the snow. Don't recommend it, not fun.
