Trickle Charge - Is it this easy?
Mike23864
NHS
So I have a Sterling DC to DC B2B charger and have bought an AMT 12-2 to keep the starter battery topped up (Leisure Battery topped up by separate solar).
Is it as simple as connecting the AMT 12-2 to the connectors in the Sterling unit labelled 5, 4 and 3 or am I a clueless :rolleyes:
5361A585-3610-47AC-94F3-0F131E5BA5C8.jpegAMT
Sadly all’s not gone to plan. Wired it up and all seemed to be good.
Went to start it next morning and it cranked but wouldn’t start as there was insufficient power. I had to use my boost charger.
I’ve put on some pictures of my setup. The Victron solar connects directly to the leisure battery.
Appreciate any help
4563E885-14CF-4D62-A90C-F57B18E53059.jpeg00C01038-D578-4516-9448-6C79382730B9.jpeg0F4C16FD-E97B-401A-8A88-348B5789BDD4.jpeg
Something doesn't sound right. I just followed the instructions that came with the AMT and everything worked fine for me, and I'm no expert.
Before I connected the unit up, I contacted Ablemail and spoke to one of the engineers who were able reassure me, regarding my quetlries on wiring procedure. It may be worthwhile talking to them.
what was the LED display?
what mode is the AMT set too?
what LB have you got?
The AMT will only charge the van battery under certain conditions. It all depends on what mode it’s set to. Basically, it won’t start charging the starter battery until the LB is just about fully charged AND if the starter battery is in a certain voltage range. IF the starter battery is below around 11V I.e. flat, the AMT won’t attempt to charge it. IF the starter is circa 12.3V I.e charged, the AMT will shut off.
Also, the output from the AMT is very low, so won’t keep up with any high parasitic drain from the starter.
You need to watch the LED on the AMT to see what’s going on.
Have you got the Sterling set up correctly to shut down when the engine is not running?
I have my AMT set to Mode7, lithium/stop-start/high current.
