Fitted a Westfalia Detachable Tow Bar earlier in the week. Just picked up the 13pin wiring kit from VW to fit over weekend.
Kit supplied has the code 7F0 055 204 B.
Just looking through instructions and it only seems to show a flat bed and mentions single or double cab. It's also shows connecting some of the wiring to an earth point on the underside of the vehicle (bit marked 3 on image). The wire for this is only 40cm long from the socket at the tow bar.
I may be wrong but when I was under the van fitting the tow bar I don't remember seeing an earth point underneath and wires not long enough to bring into van to connect to earth point in back.
Worried I might have been supplied wrong kit but thought I would double check here before so I don't make a fool of myself going back to VW.
