Having previously had 2 T4s, both of which eventually suffered from the inevitable lower sliding door channel rot, that got so bad the door would actually drop and dislodge from the door aperture while sliding it shut, requiring a deft, 2 handed, one knee, lift slide and push, all at the same time technique, just to get the damn thing to close…..I am keen to keep my T6 slider in as good condition as I can. Does anyone have any recommendations for regular cleaning/lubrication/grease/water repelling products to help maintain silky smooth door action for years to come? It’s such a luxury having a door that you can actually push and let go off and it slides shut itself, rather than manhandling and the nasty graunching, scraping sound I was used to before.
Should I pressure wash the channels regular or use some kind of rust inhibitor, it looks like a much smaller gap along the bottom channel on the T6 than was on the 4 and not sure if there is grease in there that I should avoid blasting with a washer or not?
