THQ v3 light pattern issue
Those looms are most probably to allow dipped beam to stay on with main beam.
Personally I'd get the coding changed to enable this. It's a factory setting for vans with H7 headlights, so will ultimately be more reliable than added wiring.
Do the looms not activate dipped and main beam together to save coding ?
Is there a dark area directly in front of the van without them ?
I believe the looms are to save coding, but I never fitted mine as mine were already coded.
No dark patch on mine, mine are really bright
Perfect, thanks all. Would rather not use them if I don’t have to, and now I know I’m all good. Can’t wait to get them on!
So my Ali express headlights have turned up today, going to get them fitted asap. Will post some pics when done!
Did anyone else receive these looms in the box? And if so did you use them? Just wondered what they’re for… my van was a factory h4 halogen.
Looks much the same as THQ supplied me with V2 lights, quickly corroded and caused many lighting issues. Just use Carista or similar to set up both beams for high beam.
Dare I say it?
You can get the rear lights on ali express too, also with auto start sequence 😉
Tailgate only at min
Chance would be a fine thing 🤣
They look very cool actually. Although I’m on my 3rd set of rear lights after changing my mind a few times, so I’d better not or she’ll switch. 🤣
*EDIT* wish I hadn’t seen these now… contemplating them 🤣
Hi all looking at these lights are they hard to fit or would you need to take them to a mechanic to fit?
If you take your time and watch the available videos, it's not that difficult, but does help if there are two of you to pull grill section off.
