t6stormer
Hi Everyone
I've done a search but still struggling
Vw t6 2018 150bhp dsg
Dropped the fuel tank to fit kombi brackets re fitted tank but van wont fire,
Tried transfer pump on vcds runs ok but still no start.
Next dropped the tank again, cleaned it all out with freah fuel, and new fuel filter.
Tried transfer pump test to prime lots of times but still not atarting just cranks over.
I've now removed the pipe to the inlet of the fuel filter and tried the fuel transfer test
Its just spitting out no flow at all, I've tried running the pump countkess times but still no flow.
Its pointing to a faulty transfer pump im guessing. Should i have a good flow in the pipe pictured.
The only way i could start the van was to fill the fuel filter manually and after a few cranks it started, however i tried again after an hour and it wont fire again.
Is there a way to test the transfer pump properly
