Yeah, only on with the switch.Just proven my rather hopeful thought as negativeIt does seem that the mirrors are either on or off with the switch used VCDS advance measuring to see state of switch and heating.
I also checkied in the manual - and it actually says to remember to turn it off, which also confirms what we have thought.Yeah, only on with the switch.
If it’s that important not to leave them on surely it means they should be on a timer from factory? Having said that non of the vag group cars I have owned had a timer.I also checkied in the manual - and it actually says to remember to turn it off, which also confirms what we have thought.
As an aside, I had a BMW with auto heater mirrors, and the mirror glass fell out after a number of years - I assumes it was from the mirror heaters slowly breaking down the glue that held them in place. Maybe soemthing to be aware of.
Probably wishful thinking but perhaps you could try some small number, e.g. 5, just to see if there is a mixup with the unit - e.g. minutes vs. seconds. After all, the VCDS is a third-party tool.Also has me wondering what the 600s is all about.
There is actually an "s" after the 600 (600s) which suggests seconds? I also wondered if the timer would be more relevant if there is a rear screen heater in the van (which I don't have). It may well be worth trying a much lower value, I might try next week if time/work allows.Probably wishful thinking but perhaps you could try some small number, e.g. 5, just to see if there is a mixup with the unit - minurtes vs. seconds. After all, the VCDS is a third-party tool.
I have a rear (and front) screen heater. Mirror heat stays on as long as switched to on on mine. Doesn't appear to be linked to rear screen heater in any way as far as I can tell.There is actually an "s" after the 600 (600s) which suggests seconds? I also wondered if the timer would be more relevant if there is a rear screen heater in the van (which I don't have). It may well be worth trying a much lower value, I might try next week if time/work allows.
Same here. Front and rear heated windows.I have a rear (and front) screen heater. Mirror heat stays on as long as switched to on on mine. Doesn't appear to be linked to rear screen heater in any way as far as I can tell.
I could be talking bollocks, but I think my mirror heaters may be linked to my rear window heater somehow.I have a rear (and front) screen heater. Mirror heat stays on as long as switched to on on mine. Doesn't appear to be linked to rear screen heater in any way as far as I can tell.
