Ebox 2024 t6.1
Eddie Sutherland
VCDS User
Hi all,
Does anyone know if I have to remove headlight to get access to the ebox on a 2024 t6.1. I stripped out the battery and tray as I would on the old t6 and found the ebox to be huge on this one with a small fuse box as part of the ebox lid. Removed all the screws to find it lips under the headlight am I going to have to remove said headlight or will it come out. I didn’t have the time to look further as needed to go out so thought I would ask on here. All I want to do is install the heated screen relay 🙄
Thanks in advance
The guts of the small fusebox release and drop down inside/stay put as the main plastic frame around it is lifted off
