Sucking a bit of oil out ...
or take to a local garage and bung them a drink.?
why? - oil level too high?
T6.1 with diesel was from Regens?
oil change without going underneath?
Nah it's son's Caddy. He managed to hole the sump a couple of weeks back. Had that done and there's a bit too much oil in it now so we're going to suck a bit out.
He's got his first big trip in it on Tuesday, York to Devon.
4mm id tube. It does syphon but ever so slowly! I've sent him for a drive to warm the oil up a bit more 😄
DIY oil sucking device constructed from a brake bleeder pump, skinny tubing and a jar and some hot glue. Worked quite well!
Hot oil makes all the difference.
Took about a litre out and level is now good (below max). Yes @JOG he did most of the pumping!
Yeah I’ve done that before after slightly overfilling
Honestly, nothing wrong with pulling a bit out through the dipstick tube — it’s a nice easy fix without having to mess around with the sump plug again. As long as your extractor hose goes down far enough, it works pretty well.
Just take a bit out at a time and keep checking the level so you don’t overshoot. Warming the engine a little first helps too.
Definitely one of those “wish I’d done this sooner” tricks
