I'm still pondering on the best thing to do with having staggered 20 inch wheels and dealing with a puncture....(same sized tyres, but 8.5j front and 10j rear).
If the puncture is on the rear then the spare can be used but the dead wheel/tyre will have to be carried inside the vehicle to then be repaired/replaced. You then have to hope the nearby tyre businesses have that brand/size in stock otherwise you risk a mismatched brand on the same axle.You also have to carry the original bolts with you since the new wheels use a different bolt type to the factory spare. You also have to carry the jack.
If it's the front then you can't use the spare without it being detrimental to the diff. You can't swap a rear to the front because they are staggered.
So in that case you use tyre foam but really you should be heading fairly quickly to a nearby tyres business and again you risk a mismatched tyre.
In both cases you could try a mobile repair but it may be unrepairable, or even so bad that the foam isn't an option.
This leaves me thinking that in the absence of a full sized spare and tyre that would be usable front and back, would it be ridiculous (and physically possible) to carry just a spare tyre in the carrier which is a match for your other 4? You then can use foam for a minor puncture and then drive somewhere to swap it for you, or use a mobile service to do the same.
This then guarantees you end up with the same tyre across the axle and you don't have to carry a wheel and bolts just for one specific scenario. I'm guessing you can squeeze a 20 inch tyre into the spare carrier but you would have to mod it if it was a 20 inch wheel and tyre fitted?
Now tell me I'm talking a load of *&£^ before I order myself a tyre!
Thanks people
Thanks people
